RCU Forums - View Single Post - JetCat Start Problem
Old 03-03-2012 | 08:22 PM
  #46
rctech2k7's Avatar
rctech2k7
Default RE: JetCat Start Problem
ORIGINAL: coolt5
Hi all
I just was going over all discussions just to get more info about jetcats and I have a small problem I hope u can help me with ……….
My p80 that I have for a 1 year’s already
I tried to run it and its propene start so when the sequence start after the ignition and engine go to 5000 rpm there is a fire in the Combustion chamber the engine dos not spoall up and I think it’s the fuel dos not go to the engine so I take the fuel bomb out and tray it its work only when the volte go’s 0.600 and up but lees than that it’s not working when u tray to test it from GSU ….. Is that normal or it should work from a lower voltage
Thanks in advance
How long was the last time you run your engine? To answer your question at lower voltage less than 0.6V, yes, it should work with very low rpm. Did you got over temp alarm on your engine? Prior to that did you see preheating then followed by acceleration on your screen?
