RE: JetCat Start Problem
So it means that the pump is on and required to feed fuel. You can verify that also at pump running indicator. Usually runs at low rpm just to warm up this fuel and after that you should get increase in rpm. If you didn't see any flow in your fuel line and it works when you disconnect it, it mean you might have an internal blockage also otherwise it's on the pump side...
