RE: Brushless motor shutters
The motor is controlled by the Esc, so its setting determine how it works. Did you do the throttle endpoints calibration? If your Esc has it, set it for the cell count your using. Check the start mode, it should be set to Normal. If it stills stuuters a t start up, try medium timing. Most Esc are defaulted to low timing, some motors need higher settings. On a few Esc's, PWM is adjustable, I'd use 8PWM, that normal for about 90% of all outrunners. FWIWflytreetimes
