RE: OS 33GT Gasoline Engine for Pattern
I am not surprised. Glow plugs work because of the platinum/methanol catalytic activity. I also believe that a bit more output could be had from any gas engine with a little extra oxygen in the fuel.
The most important thing for us in Pattern is getting useful mid range. If methanol gives a better responding mid range then it will be worth quite a bit to the few of us who still use wet fuels.
I finally got a few numbers using my brand new TNC tach. I checked the engine's low end, mid throttle where I fly normally, and top end. I got the following:
Low end was reliable (19x11 apc 2 blade) down to 1750; engine only has 1 gallon through it so far so this may get a little lower, but it is low enough. Sounded like a YS 170 on low throttle...very neat sound
Half throttle stick, same prop, gave me approximately 6575-6780. Temptress will do everything in Masters pattern at half throttle
Full 7450-7600 average; The tach also records the hi or peak values and at full throttle the engine would occasionally hit 7800. So full throttle gives me an average of around 800 rpm more; that's what I have in reserve. Now I know why the engine drives Temptress to ballistic speeds.
Acceleration is instant even with this large load up front but it was 41 degrees today so cooling was not a factor. I leaned the low end needle a hair and it helped a little bit. How it does in warmer weather waits to be experienced
