RCU Forums - View Single Post - JUMBO Build
Thread: JUMBO Build
Old 03-05-2012 | 08:01 AM
edoubleaz's Avatar
edoubleaz
Default RE: JUMBO Build
Believe you me that turret is a beatch. You are basically sculpting after a while. Mine still isn't right but its better than nothing! To back up a step I used the new mato metal bogies. First step was to cut off the mounting post evenly as I was attaching them to Tamiya's hull. You must also notch the plate that attaches the bogie to the hull. I then found some 4-40 bolts nuts and lock washers at the local ACE and tightened everything up.
I also tried the spring conversion on the bogie wheels. I even purchased a metal spring set from BOB/ETO. I confess I spent so much time on it I was forced to just bolt the other 5 on as is. I will get back to them later...
ID:	1735323   Click image for larger version
ID:	1735324   Click image for larger version
ID:	1735325   Click image for larger version
ID:	1735326   Click image for larger version
ID:	1735327   Click image for larger version
ID:	1735328   Click image for larger version
