RCU Forums - View Single Post - ESM tigercat twin engine location
Old 03-06-2012 | 10:54 AM
airraptor
My Feedback: (66)
Default ESM tigercat twin engine location
I just got a ESM F-7F tigercat. For now I plan to install DLE 30's. My question to all you scale guys is on the engine mounting. The engine will not fit in the cowl. the plug and wire will stick out. I know this plane isnt a super scale plane but doing little things that i can to make a little better than stock.
So what would look best?
1. have the engine inverted so that the plug is harder to see when on the ground or have it side mounted with the plugs facing the fuselage and less visable in flight.
I will also be looking at fitting smaller plugs on them to see it helps.
