RE: Has anyone tried the new PTE36R ?
Hey Cat, pull your plug out, clean it and check the gap.
Set your high (closest to the carb opening)to 1.5 turns out from closed
and the low 1.25 turns out from closed.
See if it will start from there, then tune it accordingly.
Maybe check the two bolts holding the carb and reed block on are tight.
