ORIGINAL: acerc
Update. Here's mine. Finishing up the magnetic cowl mount now. Only three minor task to be completed. 1 Glue upper wing together.................
When you get ready to assemble the upper wing & IF using epoxy, have some painters masking tape to hold it all together ON the plane as it cures! Their directions for gluing and assembling on the model are very important in order for alignment of the cabanes & thumb screws.
I also covered the fuselage with the empty wing bags so as to keep any epoxy from leaking onto it.
Paper towels & rubbing alchohol helps in clean up.
As to your photo; way too clean & tidy of a work area.....mess it up some!
AND if ya intend future 'spot' landings, might I suggest a wider table?
Looks like one wheel is on the very edge of falling off.
