RE: Have You Had Ignition Failures On Your Gasser?
Been mounting ignition circuits inside on a plate across the engine mount for 24 YEARS..Only failures were my fault, I didn't put enough electronic silicone over the circuit to keep the capacitors and parts from shaking...
Put some C&H circuits there too...Same result....
