RCU Forums - View Single Post - Getting started, on a budget, with a size limit
Old 03-07-2012 | 09:45 PM
  #38
flyfisher117
Default RE: Getting started, on a budget, with a size limit
haha so I did a little test with the glue on an un-important section of the foam lining... you would think I put acid on it, the glue just melted right on through it haha.
I cant tell of the box closes ontop of the foam sections so i jerry rigged a system to hold it down with some small screws and rubber bands, probably more complicated that need be but it holds great and is simple to open up.
Off to try and cover the nose with packing tape.<br type="_moz" />
