ORIGINAL: chopper cook
Thanks for getting back to me quicky.
head phasing is spot on I have the Align head & it is all set on the head.
When you say to Reduce your overall control throws, do you mean bring the servo rods in by a hole on the horns ?
I will have to find out if the Align 3G con be set-up to reduce the throws.
Thanks all
Yes moving the links in should help with the sensitivity.
Not sure on the Align 3G but does it still allow you to use Expo on the Tx? I would sure go there to try and tame it down a bit.
