RCU Forums - View Single Post - ECOMRC Bendix Special
Old 03-08-2012 | 11:47 PM
rcflying007
Default ECOMRC Bendix Special
<div style="text-indent: -30.1pt; margin: 0cm 0cm 0pt 30.1pt">MODEL:<span>Bendix Special</span> (ITEM NO:EC-004)</div><div style="text-indent: -30pt; margin: 0cm 0cm 0pt 30pt">Length: <span>1270mm(50</span>〞<span>)</span></div><div style="text-indent: -30pt; margin: 0cm 0cm 0pt 30pt">Wing span: <span>1465mm(57</span>〞<span>)</span></div><div style="text-indent: -30pt; margin: 0cm 0cm 0pt 30pt">Wing area: <span>36.3sq.dm (3.9sq.ft)</span></div><div style="text-indent: -30pt; margin: 0cm 0cm 0pt 30pt">Wing loading: <span>66g/sq.dm(21.6oz/sq.ft)</span></div><div style="text-indent: -30pt; margin: 0cm 0cm 0pt 30pt">Flying weight: 2.4kg(5.2lbs)</div><div style="text-indent: -30pt; margin: 0cm 0cm 0pt 30pt">Radio: <span>4ch &amp; 5servos</span></div><div>Engine: <span>4-cycle 52-70</span></div><div><span> 2-cycle 40-52</span></div><div>Motors:<span> 4250 510KV</span></div><div>ESC:<span> 60A</span></div><div>Battery:<span> 6S 2200MAH 20C</span></div><div>Propeller:<span> 14*7</span><span style="font-size: 10pt"><span style="font: 7pt 'Times New Roman'"></span></span></div>
ID:	1736603   Click image for larger version
ID:	1736604   Click image for larger version
