RCU Forums - View Single Post - NSRCA Candidate Rules Proposal Survey is available
Old 03-09-2012 | 10:47 AM
  #76
pattratt
Default RE: NSRCA Candidate Rules Proposal Survey is available
Scott
How about posting the exact verbage on all the BoD rules proposal that will be submitted to AMA. Part of the multiple survey issue was due to changing the proposals mid-stream. If you only took the first survey results, then for me it's wrong as I took the survey againg after the "change!" I am sure this affected a number of respondents. The results posted were very confusing so I went to the NSRCA site and it was still confusing but figured it out. It's probably just me but it was not easily understood. Thanks for posting it.
Dick
