ORIGINAL: 378
those other flyers are taking forever if you got two flights in before they got off the ground at all. They only have maybe 30-45 seconds more pre-flight to do than you do, they should have been queued up on the taxiway. I know I would have been. Takes me longer just to get set up than it does to get my glow cars running around, not gonna putz around with the plane either. Rx pack charged up? connections good? Surfaces wiggling right? Noise coming out of the engine? Time for takeoff
Actually if you can fuel up the plane, start and warm up the engine, make sure the engine is tuned. in 30-45 seconds than you are the best I have
ever seen. All the electric guys has to do is plug in a battery connector.
