RCU Forums - View Single Post - NSRCA Candidate Rules Proposal Survey is available
Old 03-09-2012 | 12:44 PM
  #77
smcharg's Avatar
smcharg
Default RE: NSRCA Candidate Rules Proposal Survey is available
ORIGINAL: pattratt
Scott
How about posting the exact verbage on all the BoD rules proposal that will be submitted to AMA. Part of the multiple survey issue was due to changing the proposals mid-stream. If you only took the first survey results, then for me it's wrong as I took the survey againg after the "change!" I am sure this affected a number of respondents. The results posted were very confusing so I went to the NSRCA site and it was still confusing but figured it out. It's probably just me but it was not easily understood. Thanks for posting it.
Dick
Hi Dick,
The new proposals are on the NSRCA website along with the results. I'm confused actually by your statement. There was no multiple survey, only the one. There was nothing being changed "mid-stream". We rewrote an alternative proposal that took out the arming plug but that was based on survey results and not part of the survey. My post prior was to simply state that we were listening.
Scott
<br type="_moz" />
