ORIGINAL: mstcitabria73 Alan, At what point in low voltage on the A9 would you consider unsafe to fly with the factory batteries before a charge session is needed. Also my Hitec charger's light do not go offor change colorafter a completing a newcharge, is it still charging or does it know when the battery is fully charged? Mike
1. Alarm s fixed, irrespective of battery chemistry, at 6.9v. I recharge at not les than 7.1v., as in post 130 above and new update being posted within 2 minutes:
Aurora 9 - Warning Alarms Battery types, Voltage Level Interpretation & Consumption. <font color="#ff0000">CAUTION - Leave Auto Hibernation <font size="1">(was Auto Power Off prior to V1.06)</font> as "Never" when using Lipo Battery. <font size="1">During "Auto Hibernation" (as with laptops) TX Does Not Switch everything Off</font></font><font size="1"> and batteries will be completely drained if TX switch is not manually moved to the off position in good time. Remove battery and store separately if TX is to be unused for a period.
<span style="font-size: x-small">. </span>
<span style="font-size: x-small">Aurora 9 - Lipo & Field Charging.</span></font><span style="font-size: x-small"> includes Fast Charge Aurora, Eclipse 7, Flash 4&5, Laser, Optic 6, Prism 7 etc.
2.
Aurora 9 - 110/230 Vac charger Charge Plug/adaptor sizes. [<font color="#ff0000">Red</font> LED does not change to <font color="#008000">Green </font>simply dims out but charge continues same rate].
</span>Alan T.
