RE: Intimidator II Construction Thread
Mix about an ounce of finishing resin and then add about a 10% (cap full) of 91% alcohol. The total weight with alcohol is about 1.1 ounces.
This is then applied to the right or left side of the skin. Squeegee the epoxy as needed to spread out.
The other side is done the same way.
Slide the wing core between the balsa skins.
