ORIGINAL: Lnewqban
ORIGINAL: TotalWreck
Technique for installing this power 32 outrunner? Some one told me I could use 4 long bolts, with long spacer in between two washers?[/b]
No, not long bolts there.
Just a plywood firewall between both cheeks, and having the existing engine mount as a central reinforcement.
Nice solution, I like it.
Now to say the unthinkable, I have stopped using epoxy for firewall and engine bearers. I use a good quality water proof PVA
and find that used on clean hardwood the wood breaks before the glue joint. So why use epoxy? Never use for laminating
fuselage doublers etc. PVA is air curing and your lamination may never cure. I use epoxy for this.
John
