RE: Holy Spektrum FAIL?!
Have these two planes flown correctly for a while? If so, I'd suspect a transmitter fault which would require sending it in for repair, or possibly a failing transmitter battery or battery connection. If these planes are both new, the transmitter could still be at fault, but it could also be a problem with your setup, using park flyer receivers when you need full range ones, or inadequate batteries.
