RE: Kadet LT52 Mod build DONE!!!
I have all the parts together now, ready to glue, but first i need to cut some new parts for the mods. I am taking F7 and replacing it with 1/4" plywood. The shelf is down 1/4" from the top of the fuse, so its a perfect fit. Once I have the wing aligned I will put in a couple 1/4-20 blind nuts and call it done.
The Landing gear placement though I am still struggling with. I think centered on the leading edge of the wing should work, but not 100% sure. Need to figure that out so I can put 1/4" ply backer for bolting the gear to. Once I have that then I can glue it all together.
I am still going to glue the LG block as per plans and have the nose gear fitting on the firewall just in case I want to switch to conventional LG.
