RE: Bind plug for the BNF Blade 450 3D?
A bind plug is nothing more than a jumper between the two outside wires. They are usually included with a reciever.
If you're in a pinch and have a dead servo you can snip the cord off of it, twist the two outside wires together and remove the center one or at least make sure its not hooked up to anything, and use that.
