RCU Forums - View Single Post - Has anyone tried the new PTE36R ?
Old 03-12-2012 | 06:19 PM
  #436
CAT POwer's Avatar
CAT POwer
My Feedback: (61)
Default RE: Has anyone tried the new PTE36R ?
Ok, I had some time...reset all carb settings....same result. Removed engine, checked carb seemed ok. While checked the reed valves found both valves had small pieces missing around the lower corner and two sides would not close to the reed valve cage. There is also a crack in the reed valve cage.
ID:	1738150   Click image for larger version
