RCU Forums - View Single Post - Castle Ice HV 80 II
Old 03-12-2012 | 07:51 PM
Dave Harmon
Default RE: Castle Ice HV 80 II
Bob....my motor is the EVO 30-10 and the prop is a Falcon 20.5x14.5.
I strongly suggest that you change the LVC to 32 soft cutoff because you want it to shut off before the battery gets so low it cannot restart. If the LVC is set to 30 the battery is just crowbarrred.
I have already lost an airplane this way....and I was warned several times to never....like ever....to fly more manouvers than the pattern.
Just get up there, fly em' and land immediately.
Well I didnt and I had what looked like a normal landing off the runway and the fuse buckled right behnd the gear plate.
Make sure to set the current limiting to 140A to prevent a shutdown caused by a spike.
I use the same setup on my Gaudius but that airplane does not require the higher throttle settings.
