RCU Forums - View Single Post - Engine mounting angles, how to set up a twin
Old 03-13-2012 | 04:55 AM
chymas
Default RE: Engine mounting angles, how to set up a twin
Typically on a twin you mount the right engine with right thrust and the left engine with left thrust.  Most are in the 2-3 deg range.  I remember reading an article where the guy mounted them @ 8 deg, by doing that he said he could fly single engine with no problems.  I am working on a scale project that the engines are mounted with 2 deg thrust to the outboard sides.
