RE: Throttle Cutoff for electric with 9C
Krysta,
No, I have not done the procedure that is described on page 31 of the manual you referenced. I take it that that procedure is necessary to get the trim to work properly? If I do the procedure, it says that it will reverse the throttles on all models in the memory, not just the one I want to reverse. What happens to the nitro models in memory that use the standard procedure?
Bob
