RCU Forums - View Single Post - SIMLA BUILD THREAD
Old 03-14-2012 | 05:33 PM
  #724
rg1911
Default RE: SIMLA BUILD THREAD
Bill,
You being the paint guru here, what should I do next?
The three images show one of the wing panels after a coating of a bluish high-build sandable primer and then sanding. Since I knew I had some ridges where the sheets met, I used 80-grit paper on a long sanding bar and sanded with the grain (lengthwise).
The areas that the sanding didn't hit are pretty evident. My question is: Do I continue with the prime-and-sand until the primer fills the low spots, or do I apply filler to all the bluish areas and then prime-and-sand?
It didn't make much difference with the stab, since it's fairly small. But four panels like this could use up a lot of primer and/or filler.
Many thanks,
Richard
ID:	1738793   Click image for larger version
ID:	1738794   Click image for larger version
