I made tail wheel doors...
First I made opening. I used Meister tail wheel door template, but opening is little smaller.
On the edge I glued hard wood plate 15x4 mm, and on that plate thin ply.
Edge...
Door was made from 0,5 mm thin aluminum plate. Inside I glued 2,5 mm balsa. which give aluminum strength.
I was looking how to made mechanism for opening, and finally made it with two small 9 gr servos, one for each door.
Today, with last sunlight, I finished wing sanding. I spent more than three hour to sand it, but result is great.
After cleaning, first layer of filer was added on the wing. Tonight it will dry, and tomorrow filer will be add on other side...
Regards from Serbia
Mirce
