RE: Servos fully deflect at switch on
Glad it worked.
Don't forget to RE BIND after finishing up on your workbench and every so often during the flying season.
Also, If want to have your engine come back to idle if you loose connection you need to bring back your throttle and maybe your trim to do so before you BIND/ReBIND.
At some flying events you must prove this to be the case.
I like doing it so when I am range checking my plane for the first flight of the day I have my throttle just above idle and when I get out of range it will go back to low idle I know how far my range is.
