RE: Phoenix Edge 540 1.20
Hey guys, a caution about the ailerons. I put mine together and found a couple of very minor glitches. My wing tube is too long by about an eighth of an inch, so I'll have to cut it down. Also, watch the inboard corners of the ailerons. You need enough of a gap so that at full deflection, that corner doesnt catch the fuselage. I'll have to slide one of them out a bit and cut off/trim the outboard end. Otherwise, everything's ready for assembly.
