RCU Forums - View Single Post - Kadet LT52 Mod build DONE!!!
Old 03-16-2012 | 12:19 PM
acdii
Default RE: Kadet LT52 Mod build DONE!!!
Fuse got glued together last night. All that is left is glue the corner braces on the firewall, file down F7 to fit better, glue it in, and sand the whole thing.   <div>
</div><div>For the wing mount, now that I have the fuse together, I found that the wing sits inside the fuse, not on top as I previously though, so the pin block is going to be larger. I will glue two 1/4" ply pieces together, one piece to slip inside the wing, the other to fit below the wing. This piece will have the pins in it that will slip into the F2 and ply block I installed in front of it.  </div><div>
</div><div>The tail will be done tonight, then I will work on final assembly of the wing and get it all covered, hopefully it will be airworthy by the end of the month. </div>
