RE: Flaps....to flip or twist
hemiflyer1: I used 7C Tx for several years and never found a way with the TX to slow the flap movement down. The flap setup used two PMIXes and Switch G. The flaps were set at at the half deployed position with the servos at neutral, Switch G in the middle and set to OFF. Full down used one PMIX with an OFS driving the servo, Switch G in the down position, and ON.Full up used the other PMIX driving the servo the other way, Switch G in the up position, and ON.
I have the 8FG now. The TX does have a couple of ways to slow the flap movement.
Brian
