RCU Forums - View Single Post - Evolution 26GX Preload on bearings
Old 03-17-2012 | 01:50 PM
pe reivers
Default RE: Evolution 26GX Preload on bearings
Glad you got it solved.
The construction is a bit like the glow engine front drive, where the prop drive cone butts up against the front bearing inner ring. Millions of engines run like tops that way.
