RCU Forums - View Single Post - Kadet LT52 Mod build DONE!!!
Old 03-17-2012 | 02:32 PM
acdii
Default RE: Kadet LT52 Mod build DONE!!!
Well, here are the pics of what has been done so far. ALl major components are assembled, the Fin and Stab just need theLE sanded to shape, the wing needs the fiberglass strip glued on and the ailerons fitted.
Once Ifinish up with those items, it is on to putting in the controls. Ithink Ihave the carb linkage figured out, Ispun the carb 180* to put the link inside of the mount, it was touching the mount and I had no way to get a linkage to it.
The tail wheel assembly that I have is going to take a little work to get it to fit and work correctly. The setup on the P-51 is to solder a brass tube to it, flatten the end, drill a hole and mount a ball and socket to it. Imay or may not have enough room to do that.
My scroll saw was in my barn, and Ihad to take it apart to clean it up, de-rust it, repaint it, and reassemble it. Well Iam at the repaint part, hope to have it reassembled tomorrow so Ican finish the wing bolt mod.
A few more days and it will be ready to fly! Yeah!
ID:	1739852   Click image for larger version
ID:	1739853   Click image for larger version
ID:	1739854   Click image for larger version
ID:	1739855   Click image for larger version
ID:	1739856   Click image for larger version
ID:	1739857   Click image for larger version
