RCU Forums - View Single Post - Mixing elevator to flaps with the 9C
Old 08-29-2003 | 07:23 PM
Fubar-One's Avatar
Fubar-One
Default Mixing elevator to flaps with the 9C
Hello!
Searched the manual, here, and on the Futaba FAQ page with no luck.
The plane is a Hangar 9 Ultra Stick 60 set up with airbrake on switch C per the Futaba 9C FAQ.
I also have full span aileron function on switch H per the FAQ.
Both work properly.
What I want to do is have the elevator lower when I manually lower the flaps using switch VR D. The flaps are already set up on this switch as part of the airbrakes setup as instructed in the FAQ.
I do not have a problem with using another switch for this function but since the flaps are already set up on VR D it seemed logical to use this.
Help!
Thanks in advance.
