RCU Forums - View Single Post - scale prop size on a u.s. 41 gas engine?
Old 03-18-2012 | 01:02 PM
dreid
My Feedback: (13)
Default RE: scale prop size on a u.s. 41 gas engine?
if it is a magneto engine, you will not get much if any spark flipping it by hand. A spring starter will turn it fast enough to get a bright blue spark. If the plug is good and you are getting no spark using a spring start, it is probably the ignition module. Note that the modules seldom fail. You have provided little in information about what you are doing to start and check the engine.
