RE: scale prop size on a u.s. 41 gas engine?
Ground wire is/was off. With an ohm meter I checked to see if the coil had a short, that is negative, no short.
I reset the gap between the magnets and the coil to .014 . . . . . . . NO CHANGE, NO SPARK!
I have fourteen hairs left which one should I pull?
