RCU Forums - View Single Post - 20mm Walbro for MITSUBISHI 33cc?
Old 03-18-2012 | 07:26 PM
av8tor1977's Avatar
av8tor1977
Default RE: 20mm Walbro for MITSUBISHI 33cc?
NO. If the smallest part of the throat of that carb is actually 20mm, it is far too large a carb for that engine.
No se vale. Si el diametro del punto mas chiquito de la garganta del carburador mide 20mm, es demasiado grande para tu motor. !No sirve para nada! Te va a dar nada mas que problemas.
AV8TOR
