RCU Forums - View Single Post - Intimidator II Construction Thread
Old 03-19-2012 | 09:06 AM
  #41
GSJames's Avatar
GSJames
Default RE: Intimidator II Construction Thread
ORIGINAL: twitte1
There is a mount for the 25FX made by Mike Langois. Try contacting him here. He may still make them. They fit the quickie fuse perfectly.
ml 'at' aeroprecisionmachine 'dot' com
Trey Witte
Yes, those are the mounts that Don Stegall was selling. I have two of them and work very well. I can easily switch out from my Q-25 engine to my 424 engine. I am going to try to purchase the remaining stock so that I can make them available to interested Q-25 guys.
The Magnum 25 XLS will work with the standard Viper backplate mount because that engine does not have a rear needle valve. However, the OS 25FX will not without hacking a big chunk out of the mount to clear the needle valve. Another option is to cut off the needle valve mounting bracket from the backplate of the FX and use a remote needle valve mounted somewhere else that does not interfere. http://www3.towerhobbies.com/cgi-bin...&I=LXCR44&P=ML
