RCU Forums - View Single Post - prop stud install
Old 03-19-2012 | 03:20 PM
Antique's Avatar
Antique
Default RE: prop stud install
Sounds like the hub didn't come off the crank...The hub is tapered, the end of the crank is tapered, tapped for the 6mm stud...Loctite the taper, put the hub on, tighten to 88 oz/in,,,,
