RE: Kadet LT52 Mod build DONE!!!
The wing assembly is complete, the ailerons are fitted and trimmed, the fiberglass center strip is done, all that is left is to drill the mounting holes for the bolts. For that I took a 1/16" plywood strip that covers both of the balsa blocks the torque tubes are in completely, as opposed to the ones in the kit that only cover a small part. I used one whole piece instead of the two little ones. <div>
</div><div>The tail wheel is in, and works good. </div><div>
</div><div>The covering was started last night, the stab is done, and looks really good, tonight I hope to get the rest of the covering done. Debating on whether to cover the fin in red, or white with a red rudder. The wing will be white from the main spar back, and metallic plum forward of the spar, with red, or blue ailerons. </div><div>
</div><div>It will be one colorful plane. </div><div>
</div><div>That reminds me, I need to put some filler in front of the plywood so its smooth under the covering. </div>
