RE: Kadet LT52 Mod build DONE!!!
I glued hardwood blocks in the bottom of the LT-40s I've built. I used nylon bolts for the landing gear. Using a servo for each torque rod isan easy mod. I've mounted them side by side in the wing center section.
The stock LT-40 will hover and torque roll with an OS 46FX.
