RCU Forums - View Single Post - OS 33GT Gasoline Engine for Pattern
Old 03-20-2012 | 07:44 PM
  #235
MTK
Default RE: OS 33GT Gasoline Engine for Pattern
The soft mount is extra thick and soft. The engine shake is considerable since this is a higher compression, stroked engine. Not quite the shake of a YS tho. . Still, the plane moves around at idle.
The last photo is of Aesthesis with the SAP180HP up front. Having a rear exhaust was definitely more convenient. Although the side exhaust return to center still fit inside the cavernous fuse
ID:	1740996   Click image for larger version
ID:	1740997   Click image for larger version
ID:	1740998   Click image for larger version
ID:	1740999   Click image for larger version
ID:	1741000   Click image for larger version
