RE: Kadet LT52 Mod build DONE!!!
Covering is almost done. The Stab, Fin, rudder and fuse are done. All that is left is the Elevator, wing and ailerons. Then fit the motor, radio, fuel and battery. <div>
</div><div>
</div><div>One thing I noticed that I will need to correct is one pin isnt long enough, when the wing is set in place, it site back about an 1/8th inch from F2, and I didnt have a way to look inside before I set the pin length, which I though was long enough, but isnt, so I will take them out and make them both 1/4" longer. </div><div>
</div><div>It looks pretty good in white with red feathers. </div>
