RE: How are you drilling your props
I ended up using a reamer. The original hole on the prop was 1/4" I had to go to 10mm. My reamer started at 1/4" then it went 7mm, 8mm, 9mm and finally 10mm. It came out great. I did put it on a drill press so I could regulate the feed. It was a great planes reamer.
