RCU Forums - View Single Post - Is it going lean ?
Old 03-23-2012 | 09:06 AM
WRK
Default RE: Is it going lean ?
If you want to know if it is running lean in the air you can use a data recorder and check engine temp. With some practice you will find you can tell something about
how the engine is set by listening to it. Just like the guys said it is like learning code it takes some time, I copy CW at 35 words a minute but it took quite a while to get to that speed, AB9K
