RE: Great Planes Super Sportster 60 Kit - First Timer
from my memory when i built my ss.... that is the way to install the landing gear blocks. Just make sure when you drill through the long block to be straight with the smaller block and centered where the wire sits. I remember putting the small block on the other side and drilling the hole and then test fitting with it on the proper side and glueing then. I also remember glueing some extra bass wood around the small block to the rib to beef it up, I had snapped mine off a couple of times as this was my 2nd plane. Had to recover the wing a couple of times and finally installed extra supports. This is a great flying plane and I loved the taildragger configuration. I never have had much luck with trike gear.
