RCU Forums - View Single Post - Bearing removal
Old 03-24-2012 | 07:49 AM
av8tor1977's Avatar
av8tor1977
Default RE: Bearing removal
That is correct. But many people install the bearing on the crankshaft, and then install the crank with bearing into the case. In that situation, if you need to tap the bearing onto the crank, you would tap on the inner race. Maybe my first post wasn't clear on that.
Usually, with a clean bearing bore and a warm case, the bearings go in very easily.
AV8TOR
