RCU Forums - View Single Post - engine isnt running right
Old 03-24-2012 | 06:24 PM
BIGMIG
Default RE: engine isnt running right
ORIGINAL: flycatch
ORIGINAL: tlojak38
Good afternoon everyone. I'm having a problem with an engine. I bought a super tigre g51. Now, I've been trying to tune it since last fall. My problem is, I get a good idle and and good response, but when I take it up to w.o.t. it runs for maybe 5 seconds, then dies on me. This happens almost every time. Once in a while it'll bog down and let me back off the throttle and recover it without it shutting off. I've tried two different plugs. A long plug with an idle bar, not sure of the make. A guy at the field gave it to me and told me to give it a try, and an OS8. One other thing, no matter how tight I make it, the exhaust leaks. Could that be the problem? Could it be at full throttle, there isn't enough pressure to push enough fuel to the carb? If so, how can I seal it up? Is there an oring I need? Thanks for any help.
Was the engine new or used when purchased? This brand of engine and others when run lean will eventually destroy the engine. I believe this is your problem and there is nothing that can be done so toss it and buy an OS.
I have never understood these kind of replys.?? It's like working on a ford and a member ask for some advice and you allways get the clown that says junk it and get a Chevy..............Nice reply and so helpfull.
BIGMIG [&o]
