ORIGINAL: scale only 4 me
The canopy fits the same on mine, although it's black so the gap isn't as noticeable.
I've been using the OEM tank without any issues since I took it apart and re-built it, the stopper did come loose on me, It just wasn't tightened enough, but that was my bad assuming the guy I got the plane from built it right in the first place.
Looks like they changed the horns, mine has the bolt style control horn hardware
Did you read my all posts over on that FG thread? Some things there to consider looking for in the wing tube areas, I don't want to clutter or hijack your thread here re-posting it
Something I would invest in if you don't already have, is a good set of Allen and Nut drivers, they make the 12 bolt strut assembly much easier and quicker
Thanks again, for the heads up.. I read all of the post and seen the vid on how you repaired the first wing, I will stick a tape in mine later tonight and see how far it goes in on the center section... I have the V3 version and it's got CF tubes for both wings, the fit was pretty good when I put it together last night, but I will go over it with a fine tooth comb..
If you don't mind, I would like to pick your brain a bit on thebuild of mine since you have one.. The manual still has me laughing, after reading the cover, which made no sense what so ever, I opened it up and this is what it said " BERORE you begin" Soda shot out my nose!!!!!
