RCU Forums - View Single Post - Easy Star Removing Servo
Old 03-25-2012 | 12:53 PM
Live Wire's Avatar
Live Wire
Default RE: Easy Star Removing Servo
Use a hobby knife and cut around the edges of the servo, then twist the servo back and forth to break it loose on the bottom. Water will not work[:@] all you will do is soak the foam. you cut a s close to the servo as you can and fram the opening. The servos are molded into the foam when manufactured
